Lights problem
Lights problem
Postby ianmoran » Wed Oct 04, 2017 9:55 pm
Sudden loss of headlight, speedo light, festoon and tail lights. Brake light still works, as does the horn. I thought it could be the ignition barrel was faulty, not responding to 2nd or 3rd turn. I've tried another one and the same problem persists.
Any ideas? If it was the light switch that was faulty, would the horn still work?
This is on a fairly standard S2 set up.
ianmoran
Re: Lights problem
Postby Meds » Thu Oct 05, 2017 3:37 pm
We need a bit more info on the system as the only S2 I can find with ignition is a TV with battery.
What type of stator? Is it AC or battery
Best guess at the moment is the fault is in the feed to the light circuit as the horn is working so you have power up to the head set and into the horn circuit
That would be the place to start looking and follow the wires from there- draw it out- check all,of the connections and if necessary bypass switches using shorting link to rule them out.
Another possibility is that a fault has occurred in the headset and blown the rear lamp making it look like you have lost all of the lighting circuit. check that the rear lamp is ok it might narrow the fault down a bit
Meds
Re: Lights problem
Postby grandpa » Thu Oct 05, 2017 5:00 pm
Hi,
As Meds states a bit more info 6 or 12v battery? etc.Do you have a multi meter
Have the bulbs blown ie are they blackened, check bulbs with meter or battery charger could point to over voltage from regulator which could blow bulbs but not horn also explains why brake light works.If you had an overvoltage it would only blow brake light if you were braking at the time of overvoltage.
Have you a good earth return ,use a piece of wire on side of say speedo light to earth (frame)
White wire from horn is earthed to complete the circuit when you press horn, its separate from light circuit
Grandpa
grandpa
Re: Lights problem
Postby GeorgeS » Thu Oct 05, 2017 5:01 pm
Possibly a problem with the grey & purple wires coming off the foot brake switch? Worth a quick look underneath for breakages.
GeorgeS
Re: Lights problem
Postby Leotech » Thu Oct 05, 2017 6:59 pm
This happened to me other day and it was the earth wire on the headlight bulb holder had come loose.
Leotech
Re: Lights problem
Postby ianmoran » Thu Oct 05, 2017 8:38 pm
Thanks for the replies folks.
It's on an electronic ignition, A/C , bulbs haven't blown. All been ok for past 13 years.
Yes, I do have a multi meter.
ianmoran
Re: Lights problem
Postby bookertmgs1 » Thu Oct 05, 2017 9:21 pm
Just fixed a similar problem - blew two sets of lights. Thought it was regulator.
Ended up being poor earth to headset. Wire in earth terminal had broken. was insulated terminal so I couldn't see it. Just touching when stopped but vibration when riding meant it lost contact and blew bulbs
Double check earths.
bookertmgs1
Users browsing this forum: dave81 and 66 guests
