Dimitrios_231 wrote:Nice,
for the opposite procedure,
you'll need the double nut method,
apply first a small dab of threadlocker and use a torque wrench to tighten it.
243 (medium strength) or 270 (high strength) Loctite if you know what you are doing, 8-12 N-m will be enough.
I don't know what type of engine you have,
If it is a small block,make sure that the stud won't be long enough and won't foul the cylinder studs.
If it is a large block,you won't have this problem.
Double check that once the stud is fully tighten,after fitting the exhaust gasket and stub or manifold,only the threaded part of the stud is exposed,this way you'll be able to tight correctly the brass nut.
In that case I'd prefer to use a small dab of a high strength threadlocker.
Users browsing this forum: Google [Bot] and 77 guests
