tank
tank
Postby 515paul » Tue Aug 05, 2014 8:16 am
I have a TS1 225, im using a Mikuni TMX 35mm carb, LTH manifold, the problem I have is trying to fit a long range tank, the one that takes up the space of air box and toolbox,
its the one everyone seems to sell, well with my carb/ manifold set up no way will it fit, the carb is completely in the way, I tried fitting a standard TS1 manifold, the tank just fits, a bit to tight to the carb for me, but now the float bowl touches the floor board, the carb is fairly large, my question is what tank should i use, I want to keep using my LTH manifold.
so now I have a brand new long range tank for sale, Im sure it would fit if you didnt use a TMX carb.
cheesed off
Paul
515paul
Re: tank
Postby nickw » Tue Aug 05, 2014 6:04 pm
Look at the Diablo tank. Although not sourced through Al anymore there quality and fit remains very good and I believe the chap who now sorts them will talk with you before buying and answer your question truthfully
http://www.diablotanks.co.uk/
nickw
Re: tank
Postby Toddy » Tue Aug 05, 2014 7:53 pm
I've used these guys tanks in mine good quality and fit you pay a little more but worth it
http://www.stainlessscooterproducts.com ... cessories/
Re: tank
Postby 515paul » Sat Aug 09, 2014 5:04 pm
thanks for your replys, I will have a look at the websites.
Paul
515paul
Re: tank
Postby gizmo » Sat Aug 09, 2014 8:20 pm
nickw wrote:Look at the Diablo tank. Although not sourced through Al anymore there quality and fit remains very good and I believe the chap who now sorts them will talk with you before buying and answer your question truthfully
i use one of diablos tanks with a lth manifold and it fits spot on
gizmo
