chain link spring clip
Postby gaz_powell » Sun Jul 02, 2017 12:09 pm
I'm after a chain link joint and spring clip.
I can see various sizes, can anyone confirm what size for a bretta chain - its an IRIS brand
Gaz
Re: chain link spring clip
Postby holty » Sun Jul 02, 2017 1:27 pm
as far as i know the split links available are for cheap indian chains, i could be wrong but im sure i was told iwis links are a strange size and not availalbe, you have to buy an iwis chain the correct length. probably not the answer you wanted, what size do you need ?
holty
Postby Warkton Tornado No.1 » Sun Jul 02, 2017 3:38 pm
Lambretta 'large frame' drive chains are 3/8" pitch duplex & the connecting links that are available fit all manufactures of chain that I've ever had.
They should be fitted so that the open end is clockwise.
I've never had one come adrift but I have a special riveting tool which I use with half links though the one-&-a-half links can be used with two connecting links.
