Bump stop removal
Bump stop removal
Postby SlackerThePinstriper » Fri Jun 30, 2017 12:10 pm
I'm fitting my cutdown with a 400x10' back tyre how much of the bump stop needs to be removed, roughly?
Re: Bump stop removal
Postby Knowledge » Fri Jun 30, 2017 4:36 pm
It may well fit without removing the bump stop, but the problem is that the tyre "grows" as the speed increases. You may not know how much needs to be removed until you are at speed. It may also depend on the make of tyre, as tyres of the same size do seem to vary in circumference more than you would anticipate.
I have seen engines with a bit of the bump stop filed-off, but other simply cut the whole thing off.
if you do decide to remove the whole bump stop, then keep it, as at some date in the future, you may want to weld it back on.
Postby bike grim » Fri Jun 30, 2017 8:29 pm
I need a bump stop if the whole thing is being lopped off. Alternatively if your casing is a good large block example I could do a swap with my Jet200 casing that's had the bump stop about 70% removed. Just an idea
Postby Fast n Furious » Sat Jul 01, 2017 8:41 pm
There is never a need to remove the whole bumpstop, nor is it a good idea to do so.
If the rear shocker was to snap on you, the rear tyre would then end up grinding against the mudguard if the bumpstop wasn't there to save you.
I run a 120/90/10 rear tyre on a 3" rim, which is bigger than a 400/10. The rear of the bump stop was profiled to suit providing suitable clearance but there is never a need to remove it completely.
Postby SlackerThePinstriper » Sun Jul 02, 2017 5:39 pm
Cheers for the replies lads. I'm gonna mock it up this week and have a look
