Warkton Tornado No.1 wrote:Personally, I've only known it as a slow degradation that makes itself known through difficulty in starting & even causing the engine to die when the lights are turned on.
You might need to look elsewhere as the problem with 6 volt lighting is that any wiring & connections really need to be in first class condition.
As a matter of interest, although I wouldn't suggest you get rid of your points, but are you persevering with 6 volts as a 'purist?' I only ask because conversion to 12 volt is a good thing to consider.
Scooterslag wrote:Warkton Tornado No.1 wrote:Personally, I've only known it as a slow degradation that makes itself known through difficulty in starting & even causing the engine to die when the lights are turned on.
Cheers for the reply, I retain using the points set up as in the last 20 years of ownership of the scoot, they've been reliable, I rebuilt the bike ten years ago using new loom, rectifier etc etc and always kept on top of maintenance with the system. Gone are the days of the late 80's/early 90's 'fit and forget' AF electronic kits, now it seems no one (including the more expensive makers) can make a stator and flywheel to last . Read a rally write up recently where a bloke used two variatronic stators getting to a rally -sod thatthe bikes only a local run about and standard so points are fine. I was thinking , would a dodgy bulb holder cause dimming in the lights? cheers Paul
a-teamlambretta wrote:may be the nice mot man put you a 12v bulb in , check them
Fast n Furious wrote:A short circuit in the lighting circuit will also cause dim lights and is more likely than a high resistance niggle.
I suggest that you make up a tester using a car headlight bulb (An H4 or H7). Connect it directly to the stator output with nothing else connected to the circuit (Rectifier/Regulator/ loom wiring and other bulbs).
If the lamp burns brightly then you know its not the stator and you can then move forward connecting back each piece of kit until the fault returns.
Voila.
