Another jetex question
Postby Charliebubble47 » Thu Jun 22, 2017 5:49 pm
Hi All
I read on one of the threads that a lot of dellorto carb parts are interchangeable with the jetex carb parts.
Has any one got a list of them or point me in the right direction, I have a jetex SO1-100 if that's any help
TIA
CB
Charliebubble47
Re: Another jetex question
Postby St George » Thu Jun 22, 2017 6:02 pm
The jets are interchangeable for sure.
St George
Postby ToBoldlyGo » Thu Jun 22, 2017 8:46 pm
No, they are really not. The carbs might look similar, but that's about it. You'll get into all sorts of trouble if you start swapping parts around. The float bowls are a different capacity and the Jetex requires a longer needle. A Jetex slide will not work in a Dell'orto either.
Postby Charliebubble47 » Sun Jun 25, 2017 4:23 pm
Thanks for that, I will bear that in mind
Charliebubble47
