by Cgt75b » Sat Jun 17, 2017 8:40 pm
Hi folks
Just ordered a few bits and bobs from scooter rezzies. One of the things was a nylon/plastic collar for the gear change.
The problem being when I feed the grip with the gear change rod through it doesn't close the gap enough, if you know what I mean. If there a difference between series 2/3?
Cheers for any help.
Cgt75b................
by Watfordwhite » Sat Jun 17, 2017 10:15 pm
Yes there is a difference between S2 and S3. However there is also a mass e difference between Italian S2 and Indian S2.
This could be your problem.
Watfordwhite
by HxPaul » Sun Jun 18, 2017 8:09 am
Cgt75b wrote:Hi folks
Series 2 use different spacers and bushes to the series 3.
http://www.ebay.co.uk/itm/Lambretta-Ser ... SwoudW1zXv
by JETEX » Sun Jun 18, 2017 12:19 pm
I've had a similar issue with my Series 3. I may have the 'wrong' collar ?. I've fettled it a bit and it's almost right, with maybe 1 mm gap between the twist grip and the casting. I'm hoping that it will wear in.
JETEX
by Cgt75b » Sun Jun 18, 2017 9:53 pm
Thanks for the help think I have it sussed now.
Users browsing this forum: No registered users and 17 guests
