Jet Electrics Dilemma...
Having given Italy a miss this year I've been muttering with clubmates about doing Euro Spain next year and talking about possibly rebuilding the engine of a Jet 200 that came into my possession recently, however, it would be my intention to 225 it and sort out some of the issues that some of the original Spanish components that they (at least some of the variants) were fitted with. As well as allowing it to breathe a little better, the standard small toolbox variant struggling to supply enough airflow for the standard Jet motor configuration, I will have to sort out a freer flowing exhaust to allow the motor to rev on more freely (BTW this bike came with a spare factory SIIII exhaust with cut tailpipe, as per the original still fitted) as the standard exhaust has a sealed entry pipe in the neck of the exhaust (similar restriction to the 'mushroom baffle' type that many blame poor Jet performance on) however, these exhausts have a sealed entry pipe with just a few (4 or 6) 8mm'ish holes going through into the exhaust box body. Just as I'd read about in a number of older period texts, that exhaust design completely strangles anything that wants to rev a little or pass any larger capacity volume of exhaust gas. I've ridden this bike in standard trim and it feels amazingly relaxed and just hums along but only hums up to what is realistically high 50s and then allows no more, just as described in period texts.
Anyway, back to the point, the issue that concerns me most is the crank/flywheel/electrics configuration. Sure, I've read countless quotes of high mileage Jets and talk of assembly errors or weak components being responsible for any failures, however, I've also read countless reports of crank tapers shearing, and have 3 examples of clubmates shearing Spanish cranks with Motoplat electronic flywheels, 1 Spanish friend shearing her taper on her Jet200 Motoplat points example, a mate repeatedly shearing tapers on his standard Innocenti TV200 and 1 example of an SX200 shearing its taper. Added to this you find the issue of flywheel/taper shearing being acknowledged in the Official Home Workshop Manual, and countless other instances being rolled out when this issue gets raised, time and time again, on forums. So, in light of this I'm considering my options for keeping this motor 'in character' yet addressing the weak link. Currently my mind is working along the option lines of:
1. Risk it and carry a spare crank, flywheel and stator. I'd even keep it as the original configuration.
2. Look into flywheel options as a lighter flywheel massively reduces the chance of it shearing the taper of the crank. I was comfortable enough to build up a spare Milan engine in 1997 which, following big end failure on a high mileage engine, was put into service and this used an LI/SX type crank with lightened 4-pole flywheel and fan... not missing a beat and then continuing to run very reliably in a different frame for a number of years.
In changing flywheel I could even consider swapping to electronic with one of the Indian produced AF flywheels, however, I've first hand experience of 2 of those having magnet covers come loose and trash the stator, which would rather negate the idea of improving reliability!
3. Rebuild on the stronger foundation that is a GP crank and then use whatever flywheel I like, opting for points or electronic. Potentially, I could swap coils from Spanish stator base plate and put them onto a suitable Italian or Indian laminate thickness, condenser would need to suit though.
4. Go GP crank and look to replace the Motoplat centre boss with a GP item but I do not currently even know if the bosses are interchangeable / rivets in the same positions (anyone tried this?). If this could be done then I could even keep the original Motoplat stator.
5. Stop messing about and swap out the Spanish crank and electrics for something more reliable and maintenance free (GP crank and decent electronic ignition)!
Hmmmm, how far to go before keeping it standard'ish becomes not standard'ish enough?
TBH I don't even know if I will do Spain yet and/or whether this bike would be ridden... but there's nothing like planning early
As ever, your thoughts/feedback is welcomed, ta.
Adam
Adam
