Li 150 box
Li 150 box
Postby jonno » Sun Jun 04, 2017 7:08 pm
Is there any difference between Li150 fourth gear from any of the manufacturers? I replaced my 4th,I measured diameter and across the teeth and it seemed the same but it will not drive in 4th at all.Will take apart engine to look but just want a heads up on any differences.
jonno
Re: Li 150 box
Postby CHRIS in MARGATE » Sun Jun 04, 2017 8:17 pm
3rd and 4th loose gears in the right way round ?
Re: Li 150 box
Postby jonno » Mon Jun 05, 2017 11:07 pm
Yep in the right way.The new cog is 0.2mm wider across the teeth but the same as the old one in overall thickness.Gear cables badly loose for some reason,could explain not getting 4th very easily.Could the sliding dog ever try to turn 2 gears at once,because of badly adjusted cables?
jonno
