Warkton Tornado No.1 wrote:I've used Rawl nuts for some time, but recently took them off. I fitted floating anchor nuts as they give the opportunity to use more of the full extent of the slot than the Rawl nuts due to the outside diameter of the rubber.
Rawl nuts will suit some, but if you need the almost full extent of the slot, (as I did) the SLUK items seem a better option to me.
"Horses for courses" eh?
Nice to have a new option, IMHO.
Topgearskin wrote:
what size would you need?
coaster wrote:Warkton Tornado No.1 wrote:I've used Rawl nuts for some time, but recently took them off. I fitted floating anchor nuts as they give the opportunity to use more of the full extent of the slot than the Rawl nuts due to the outside diameter of the rubber.
Do you mean these WT? http://www.ebay.co.uk/itm/Cage-Nuts-Cag ... AugOCuPFSA
I've just fitted them to my LiS, needed to file the strut holes with a square file a bit but work perfectly.
grandpa wrote:Hi
Yes,another good idea for the bridge piece problem
You could use a bolt from underneath place a tap washer or anti vibration washer to stop bolt falling out and refit bridge piece with
stainless steel washer and dome headed nut.If bolt head turns a long bladed screw driver can be used to stop bolt turning.
Not for purists
Grandpa
