Serveta toolbox/airbox,and GP engine
Postby kevspeed » Sun May 14, 2017 7:51 am
Im helping a mate with his scooter,and he's bought a standard S.I.L 200 engine to fit.
Its got the usual 22mm carb,and big bore pipe,but he's concerned about the airflow from the Serveta toolbox/airbox.
Now im sure ive seen the airhoses made to suit the 22mm carbs and the serveta airboxes somewhere,so im pretty sure that airflow wont be a problem.
Anyone run this set up,and if so,any problems encountered or modifications needed ?
Thanks in advance.......Kev
kevspeed
Re: Serveta toolbox/airbox,and GP engine
Postby Hornbyfrog123 » Sun May 14, 2017 8:32 am
I have standard 200 gp engine on series two and have no issues with airflow or filtration. Standard carb set up and all works fine.
Hornbyfrog123
Postby rossclark » Sun May 14, 2017 11:06 am
Scootopia or Restos do the 22mm hose for Serveta.
Postby kevspeed » Mon May 15, 2017 3:34 pm
Hornbyfrog123 wrote:I have standard 200 gp engine on series two and have no issues with airflow or filtration. Standard carb set up and all works fine.
rossclark wrote:Scootopia or Restos do the 22mm hose for Serveta.
8-) 8-) 8-)
kevspeed
Postby St George » Mon May 15, 2017 5:41 pm
I bought one of those from there, spot on.
St George
