by bluebob » Sat May 13, 2017 11:48 pm
just taken the mag housing off,to take the crank out .the grease in the housing is jet black ,and some grease is in the inner oilseal on the crankside.plus a bit on the crank.new seals and bearing about 700 miles ago.is it likely that my grease is not high melting point ,as it is supposed to be.any ideas please.
bluebob
by Tractorman » Sun May 14, 2017 9:09 am
It could be, I have looking for some more HM grease (my stock from my working days is almost out
) and some of the so called high melting point grease ranges are 130 degrees.
by Warkton Tornado No.1 » Mon May 15, 2017 9:22 pm
I’d be inclined to check that the inner seal is not leaking allowing contamination via the petroil (within the bottom end) getting to the magneto area.
The roller bearing shouldn’t get that hot to cause problems with any grease, if you think about it, although the rotation of the bearing will cause some heat on its own. After all, the seals are only made of some kind of rubber & they do melt if things get too hot in there!
by bluebob » Tue May 16, 2017 8:21 am
thanks chaps.for peace of mind I will change the grease,and fit a new seal.got some rolf seals somewhere.
bluebob
