li125 special brake light problem
Postby johno58 » Wed May 03, 2017 1:56 pm
[youtube-share][/youtube-share]I have a 1966 125 special running 6v electrics ,the scooter as only done 2200 km from brand new as it had a carb fire in 1967 and as stood in Italy until 2013 ,hence I would like to keep everything stock.I replaced everything that had burnt ,namely wiring and cables and tyres and seat and it sailed through its MOT.
that was last year but when I come to take it for the MOT this year I have no rear brake light.First I changed the bulb but no luck so next I disconnected the two pink wires
from the brake pedal switch and connected those together thinking it could be the switch but again no luck.
I started the scooter and swapped the pink and black wires in the bulb holder thinking it could be the bulb holder,the black wire lit the stop light , so no problem with the bulb holder ,now I'm not good at all with electrics but I know how to test for continuity so with my voltmeter I checked at the junction box to brake light on the pink wire and I have continuity????? why am I getting nothing ,can anybody give me any pointers as to what to check next please ,the scooter will start no problem and all the other lights appear to be working fine ,need to get this sorted before Italy in 3 weeks and while I could take it to a shop id rather try and sort this for future reference and also to learn more about the electrics.
johno58
Re: li125 special brake light problem
Postby St George » Wed May 03, 2017 3:39 pm
I use a spare battery to test my electrics with this type of fault. However I always disconnect the AC power cables first. Works for me, saves testing with the engine running. Probably the joint at the bulb holder.
St George
Postby Rich Oswald » Wed May 03, 2017 3:53 pm
Johno, welcome to the forum. This section is for Forum problems so you would be better posting in Series 1,2,3 section,
Cheers,
Postby Wack » Thu May 04, 2017 7:15 pm
If your stator has a pink wire from it to the junction box, unplug it and test for voltage as it may be faulty. The loom pink can be fitted in place of the loom brown to check power through it.
Users browsing this forum: Google [Bot] and 70 guests
