Exhaust nuts
Exhaust nuts
Postby Tim_Craig » Mon Jul 28, 2014 11:07 pm
Looking for opinions on which are the best exhaust manifold nuts to use.
I picked up some copper plated exhaust lock nuts on the Euro rally to Switzerland which seemed to work really well, got a few spares as well, lol.
I have however, been told they are crap & brass are better, what are the pros & cons then?
Thanks for any info you can give. Cheers Tim.
Tim_Craig
Re: Exhaust nuts
Postby lammydave » Tue Jul 29, 2014 6:56 am
the exhaust nuts are brass for a reason...
it's my understanding that because they are brass, they dont corrode or bond to the stud/flange as badly as if they were steel.....
lammydave
Re: Exhaust nuts
Postby Tim_Craig » Tue Jul 29, 2014 8:56 am
lammydave wrote:the exhaust nuts are brass for a reason...
Thanks, I believe you are right however, the copper plated ones are plated for this reason also.
I have never seen brass lock nuts and brass being not quite as hard as normal steel means threads can be stripped a lot easier if over tightened.
This is one of the reasons I thought the copper plated lock nuts would be better IMHO.
I could be totally wrong in my thinking here though, any experts out there?
Cheers Tim.
Tim_Craig
Re: Exhaust nuts
Postby drivera » Tue Jul 29, 2014 9:08 am
Brass nut , spring washer then flat washer , dab of Loctite on the stud and bob's your uncle :) , always use a ring spanner or socket so as not to round off the edges and you shouldn't need to shift the nuts unless you want to drop the downpipe , then just use another pair of brass nuts
drivera
Re: Exhaust nuts
Postby coaster » Tue Jul 29, 2014 11:51 am
it's my understanding that because they are brass, they don't corrode or bond to the stud/flange as badly as if they were steel.....
That would be my understanding too, I have a GTS for commuting that had steel exhaust nuts fitted from new and one has snapped the exhaust stud and the other rusted so badly that the remains of the nut had to be ground off and new studs and nuts fitted. Mind you that is a 4 stroke and it doesn't benefit from 2 stroke dripping onto then through leaky gaskets :oops:
Re: Exhaust nuts
Postby bolzenanker » Tue Jul 29, 2014 1:16 pm
Tim
Loads of suggestions on this thread:
viewtopic.php?f=10&t=233
bolzenanker
Re: Exhaust nuts
Postby Tim_Craig » Tue Jul 29, 2014 4:59 pm
Thanks Gents,
Going to give the copper plated lock nuts a try, see how they perform long term. Agree studs should be loktited in also.
Cheers Tim.
Tim_Craig
Re: Exhaust nuts
Postby trotsky » Tue Jul 29, 2014 9:59 pm
Hi Tim, I've used " K " nuts on our Ts ( & Vega ) exhaust studs for years, found them to be excellent. 7mm thread - 8mm spanner, I use a long 6 point socket. Hope this might be of use?....Steve
trotsky
Re: Exhaust nuts
Postby Tim_Craig » Wed Jul 30, 2014 10:22 am
trotsky wrote:Hi Tim, I've used " K " nuts on our Ts ( & Vega ) exhaust studs for years, found them to be excellent. 7mm thread - 8mm spanner, I use a long 6 point socket. Hope this might be of use?....Steve
Thanks Steve, googled them & they look to be worth a try also.
Cheers Tim.
Tim_Craig
Re: Exhaust nuts
Postby bigbthesoulman » Wed Aug 06, 2014 9:46 am
Hello you havnt a link for them nuts do you,interested to try them
bigbthesoulman
Re: Exhaust nuts
Postby rossclark » Fri Aug 08, 2014 9:31 pm
Just google k nuts loads of places sell them
