Cylinder tight on studs.
Postby Scooter Paul » Sun Apr 23, 2017 11:41 am
After 50 years of Lambretta repairs a new one on me; cylinder was tight as a tight thing on the barrel studs. Wasn't corrosion. One of the exhaust studs had wound slightly too far in and was trapping the corresponding stud. I'm sure it's been covered before but as I said; when you think you've seen everything.....
Paul.
Scooter Paul
Re: Cylinder tight on studs.
Postby Topgearskin » Sun Apr 23, 2017 4:08 pm
I had this with my new Gori 200 barrel. Swapped the studs thinking one was bent, no better. Ended up having to drill out the stud holes. Another Lambretta test!
Topgearskin
Postby holty » Sun Apr 23, 2017 9:45 pm
just came accross the same thing today, just shortened the stud a little then re-fitted problem solved.
holty
