stand
stand
Postby eyeguy » Sun Apr 02, 2017 1:00 pm
Is this stand bent or not? the scooter would rock back and forth. I know the feet were worn. Want to make sure the left side as you look at the pic is correct.
eyeguy
eyeguy
Re: stand
Postby EddieStone » Sun Apr 02, 2017 9:50 pm
I think one leg is different to clear the exhaust. Lambretta stands are not meant to lift a wheel in the air, they just stop it from falling over.
EddieStone
Re: stand
Postby Knowledge » Sun Apr 02, 2017 10:13 pm
The stand looks about right.
Most issues with stand rocking are related to where the stand-hooks clamp through the frame cross member. Often, the bolts will start to pull through the crossmember. With age, it all starts to get a bit ugly, and repair usually involves heating, welding, grinding and painting.
Re: stand
Postby eyeguy » Sun Apr 02, 2017 11:54 pm
Thanks for the replies. I changed the feet and all is good
Eyeguy
eyeguy
