bottom damper brackets
Postby lammydave » Sat Apr 01, 2017 5:13 pm
Trying to find a decent set of bolt on bottom damper brackets
I have had 2 sets and the threaded part is crap alloy and the thread just gives in when any pressure is applied
have searched the web, but they all look the same crap alloy ones
Anyone had a decent set with a proper "bolt" part??
lammydave
Re: bottom damper brackets
Postby Norrie Bodge » Sat Apr 01, 2017 5:44 pm
They all KAK m8
pull the links out of ya forks & send them to Shocky
he`ll weld damper mounts onto them for you!!
great job he does & at a great price too
heres his email -> smallen2009@live.co.uk
Norrie Bodge
Postby Digger » Sat Apr 01, 2017 5:46 pm
Why don't you ask Steve (Shocky) to weld lugs on your links - much better than those clamps.
Digger
Postby ToBoldlyGo » Sat Apr 01, 2017 6:27 pm
I'm not entirely sure what you mean there Dave. Do you mean the bolt on damper brackets as per your dearly departed SX, or the damper studs that screw into the links? I only ask because the latter is readily available from reputable dealers.
Postby lammydave » Sat Apr 01, 2017 7:13 pm
ToBoldlyGo wrote:I'm not entirely sure what you mean there Dave. Do you mean the bolt on damper brackets as per your dearly departed SX, or the damper studs that screw into the links? I only ask because the latter is readily available from reputable dealers.
The bolt on brackets.. the stud part is cream cheese....
lammydave
Postby gaz_powell » Sat Apr 01, 2017 11:46 pm
Im working on two bikes at moment that have them fitted and they are decent. Sorry no idea where they are from but they are out there.
Not tried them but Casa make some
Preference would be welded in the longer run.
