Chain guides?
Chain guides?
Postby eadmr04 » Sun Mar 26, 2017 9:44 pm
Is it advisable to keep the bottom chain guide once replacing the top one with a nylon slipper adjuster or is it best left out?
eadmr04
Re: Chain guides?
Postby Toddy » Mon Mar 27, 2017 6:08 am
eadmr04 wrote:Is it advisable to keep the bottom chain guide once replacing the top one with a nylon slipper adjuster or is it best left out?
I think you will find differing opinions personally i dont fit a bottom chain guide
Re: Chain guides?
Postby Knowledge » Mon Mar 27, 2017 2:06 pm
If it helps you make a decision Dom, the chain goes tight at the bottom when the engine is pulling, which means it should be off the bottom of the chain casing,
Personally, I lose the bottom guide, but as Toddy says. opinions vary (Marmite time).
I suspect there will be some further posts.
Re: Chain guides?
Postby Norrie Bodge » Mon Mar 27, 2017 2:12 pm
ive used these type & find ok
Norrie Bodge
Re: Chain guides?
Postby eadmr04 » Mon Mar 27, 2017 3:06 pm
Knowledge wrote:If it helps you make a decision Dom, the chain goes tight at the bottom when the engine is pulling, which means it should be off the bottom of the chain casing,
Is there any reason why not to leave it in place?
eadmr04
Re: Chain guides?
Postby HxPaul » Mon Mar 27, 2017 4:28 pm
Norrie Bodge wrote:ive used these type & find ok
Sometimes this type of bottom chain guide can be to thick at the front,effectively adjusting your chain on the bottom run.
Re: Chain guides?
Postby Norrie Bodge » Mon Mar 27, 2017 4:45 pm
ye agree, just dremelled them a bit to fit better
Norrie Bodge
Re: Chain guides?
Postby gaz_powell » Mon Mar 27, 2017 4:49 pm
/\ agree depending on what front sprocket you have.
I like a bottom guide so have shaved them down or re angled them to endure the chain is flowing nicely.
The ScootRS ones I found were the best of the bunch, not available anymore ??
