Viagra for floppy brake pedals
Postby Sticky » Wed Mar 22, 2017 8:14 pm
https://www.scooterlab.uk/lambretta-brake-pedal-pin-repair-workshop/
Here's a full how-to of a tip that we mentioned in the Spanners Manual. I hope it is of assistance.
Sticky
Re: Viagra for floppy brake pedals
Postby EddieStone » Wed Mar 22, 2017 10:53 pm
I did this to mine. Bit nerve wracking hacking off a bit of a re-built scooter, which is only surpassed by the thought of the tap snapping off, but it worked perfectly.
EddieStone
Postby Phil D » Thu Mar 23, 2017 6:01 am
The original brake pin is only tacked in and easily removed from the saddle .
New pins are available from S/R .
I had the circlip groove machined in and also the grease nipple thread and side hole then just re- tacked it in place having measured how far the old one stuck out .
I did't have Sticky's then so was flying by the seat of my pants.
I'm not sure if I'd have gone to all the trouble if I had. ;)
Great idea explaining the process in more depth.
I bet theirs loads more material in the book. ;)
Thanks.
Phil D
Postby Wack » Thu Mar 23, 2017 6:55 pm
If you save all your old brass gear shaft casing bushes these fit far better than the nylon pedal inserts
Postby Sticky » Thu Mar 23, 2017 7:09 pm
Good point Wack
Sticky
