Stand & Scootopia Clubman
Postby Eibar-Jet200 » Mon Mar 06, 2017 2:24 pm
Afternoon all,
Building the scoot for Italy and fitted a new splashplate and sorted the supports for the stand. Had the PM on and all was good.
Decided to fit a Scootopia Clubman and standard carb now the stand won't come all the way up on either side. One Step Forward Two Steps back on my build! :evil:
Anyone else had this problem?
Can I bend the stand out? What is the best method for that? A trolley jack on it's side?
No runner boards on the scoot.
Any advice greatly appreciated. :D
John
Eibar-Jet200
Re: Stand & Scootopia Clubman
Postby HxPaul » Mon Mar 06, 2017 3:54 pm
I have a series 2 and a series 3 both have a scootopia ancilotti type clubman fitted and both center stands come all the way up without touching the exhaust.
Postby ToBoldlyGo » Mon Mar 06, 2017 9:07 pm
You haven't got it on back to front, or something?
Postby dickie » Mon Mar 06, 2017 9:29 pm
I had the same problem albeit with a tino ancillotti; same dimensions I believe.
I fettled the splash plate so that i could move the stand a little further to starboard, but i still had to bend the stand out a little on that side. I bent it by standing on one leg and pulling the other. Possibly not great for your back if you're an average age scooterist. Obviously I had to remove the stand to do this.
My bgm clubman is easily clear.
Postby Eibar-Jet200 » Mon Mar 06, 2017 9:47 pm
Thank you all.
That will be a task for Saturday morning.
John
Eibar-Jet200
Postby Eibar-Jet200 » Mon Mar 13, 2017 6:00 pm
Well, the stand came off.
It was too hard to pull and bend with my dodgy back.
So using the drain in the street and a trolley jack the stand was bent.
Now fits past the exhaust on both sides.
Job done.
John
Eibar-Jet200
