front brake
front brake
Postby daniel whiteley » Sat Mar 04, 2017 8:04 pm
so ........ im just fettling my curry burner gp and im trying to put thr front hub to a correct state as there are clips washers seals missing , been trying to find a correct component list build up procedure for the brake arm and hub spindle , all i can find are the parts diagrams with the numbers but no description and it doesnt say in stickys book so can anyone help with order of what goes on where , brake cam then washer ect
many thanks
daniel whiteley
Re: front brake
Postby HxPaul » Sat Mar 04, 2017 9:37 pm
Not sure whether this is what you already have,but it shows you the order which things are assembled.If you click on the oblong box at the top of the page (Lambretta wheels/brakes/tyres/tube (138) http://www.scooterrestorations.com/lamb ... res-tubes/
Re: front brake
Postby daniel whiteley » Sun Mar 05, 2017 7:58 pm
hi paul yes seen loads of those but i dont know what the actual parts are ??? are they washers or seals , if they had a list of what number was what it would be ok
daniel whiteley
Re: front brake
Postby gaz_powell » Sun Mar 05, 2017 8:41 pm
Use the SR illustration, Click on the number and it will take you to the part and tell you exactly what it is and usually with a picture.
Alternatively get a SIL parts manual (from SR?) and it gives the illustrations and the part description
Re: front brake
Postby daniel whiteley » Sun Mar 05, 2017 9:02 pm
i didnt know that , cheers thats a great help
daniel whiteley
