Oil capacity on Italian LI 125 1960
Postby gunfox » Sat Feb 18, 2017 3:14 pm
Hi All.
In My Haynes manual it states that the gear oil capacity is one & a quarter litres, but I can only get 550ml in before it comes out the level hole, I put it in very slowly, until it starts to come out, then wait about ten minutes before trying again (very slowly) but it shows it full, am I missing something I should be doing?
gunfox
Re: Oil capacity on Italian LI 125 1960
Postby Digger » Sat Feb 18, 2017 3:50 pm
1.4 litres is about double what you need - when it comes out the level hole you've added enough.
What you should be doing is binning the Haynes and get Sticky's. ;)
Digger
Postby HxPaul » Sat Feb 18, 2017 4:15 pm
700ml from dry (ie.rebuilt gearbox, etc.).500ml wet (ie.oil change)
Postby gunfox » Sat Feb 18, 2017 4:41 pm
Thank you all for that.
Bike is running now, but carb leaks a bit, so just going to buy new one, too old to muck about trying to sort out old one.
gunfox
Postby Warkton Tornado No.1 » Sat Feb 18, 2017 5:44 pm
....if only marriage licenses were like the TV type, renewable every year......
Postby byron » Sun Feb 19, 2017 4:17 pm
gunfox wrote:Hi All.
:o
1¼ pints maybe...
byron
Users browsing this forum: Google [Bot] and 60 guests
