MK Monty wrote:Depends if you want to see what's in front of you
Bin the coolies hat and reeded glass that just glow and scatter the light and go for a Jockey B headlight then you can look at different options of H$ halogen or HID lamp options
Tractorman wrote:MK Monty wrote:Depends if you want to see what's in front of you
Can only agree with MK Monty these light are brilliant it a pity they don't make them for GPs.
Fast n Furious wrote:I'd like to see if a Scomadi lamp will actually fit a GP.
I had read on me grapevine that the glass is slightly smaller, which is better than bigger of course.
Can anyone confirm?
Meds wrote:A few question for those with jockey headlights.
How much room is left inside the head light?
what did you use as a connector block?
What's the best lamp to use? (it Seems a bit silly to spend £60 on a quality reflector and put a crap lamp in)
coaster wrote:Edit: I just had a closer look at the photos and it looks like that is an HID lamp in there. The lamp base is the same as my HID and other giveaways are that there are only 2 wires going to it and also looking at the front of the lens, you can see the chromed shroud that covers the lamp. My Jet doesn't have the shroud fitted and the light is amazing out on the road. My LiS has the shroud but I've only tried it in the driveway...did SEEM similar though
Knowledge wrote:........................... He purchased an HID kit off ebay, but it was a two-lamp kit and needed modifying to suit the Scomadi. As he was electrically inept, he asked me to have a look at it when I was round his house measuring-up the size of the headlight.
Fast n Furious wrote:It certainly looks like the Jockey boxenstop SX and LI lamp assemblies came from the same plant that made these Scomadli GP units.
Users browsing this forum: No registered users and 95 guests
