Post by grandpa » Fri Feb 10, 2017 4:49 pm
Hi
Do you really want to drill holes in your side panel?
Have a look at this
viewtopic.php?f=10&t=753&p=4660&hilit=side+panel+security#p4660
You can get security allen bolts with a raised stud that need an allen key with a central hole to fit over stud
Grandpa
mick094m wrote:Before you go drilling holes , look on ebay for hole metal hole punches lot better , you drill a small hole then use the punch screw in with and allen key cuts a perfect hole with less damage to the metal of your panel, also get your locks from..........."Locks on line" , much cheaper and better quality than dealers ,
Users browsing this forum: Google [Bot] and 74 guests
