Fast n Furious wrote:The content of your post suggests the engine is finding it hard to breath. Check your air filtration. (Have you left anything under the seat that could block the breather scoop?)
MickYork wrote:Need more info'.
What scoot is it ?
Is it kitted ?
What carb' and settings ?
Open mouth or filter ?
Advance/retard ignition ?
What is ignition set at ?
etc
etc
Sounds like your bogging down .....too much fuel to air ratio...
or it could be stator breaking down........cooling.....then working again.
Have you got a Sticky's manual ? worth getting one and having a read.
MickYork wrote:try it without the air filter.......
coaster wrote:Are absolutely certain that your choke is closing properly? there should be a bit of slack at the carb end when it is in the off position.
Charliebubble47 wrote:MickYork wrote:try it without the air filter.......
Will give it a go tomorrow and see what happens
Out of curiosity what would be the best set up on the carb,
just looking at stickys book and my carb is set up for a gp150
Slide:7895-2
Atomiser:5899-4
Main jet:118
Pilot:45
Starter jet:50
Would this be causing the problems
lammydave wrote:make sure your petrol tank cap is breathing
