Post by Tractorman » Mon Jan 02, 2017 9:56 pm
If the stud is a fairly good fit in the hole you could use an very high strength Loctite, 610 is good. Put plenty on the stud and hole and fit the rim using a spanner to hold the stud and tighten up the rim. Leave to cure for 24 hours. If you ever need the stud out you will need to use heat to break the Loctite's grip.
Tractorman wrote:If the stud is a fairly good fit in the hole you could use an very high strength Loctite, 610 is good. Put plenty on the stud and hole and fit the rim using a spanner to hold the stud and tighten up the rim. Leave to cure for 24 hours. If you ever need the stud out you will need to use heat to break the Loctite's grip.
Warkton Tornado No.1 wrote:
I'm not sure of the best grade of Loctite to use, but, TBH I've had to resort to this solution with the rear hub several times (Serveta rear hubs don't grow on trees) without too much concern.
My belief is that the Loctite will get the hub stud back as close to an intended fit as possible & resist any 'slippage' or fretting which a non fitting fastener will not achieve.
Post by dickie » Mon Jan 02, 2017 10:50 pm
The stud only just slips, I guess both you guys are right. I'll get some permanent loctite threadlocker.
I was inclined to get the oversize stud but this is cheaper and easier. Plus I'd have a left hand imperial tap in my tools and it would irritate me until I died.
ToBoldlyGo wrote:
That's enough to give you nightmares. Didn't you ever check to make sure they were tight?
Adam_Winstone wrote:I've seen a couple of cases of this recently, where people have used commonly available dome nuts and the original type washer. Unfortunately, the washers are thin and the dome nuts are low/shallow, resulting in the nut finishing extremely close to/against the washer/rim, however, the nut had actually bottomed out on the top of the stud and was applying little or no pressure to hold the rim to the hub. In one of these cases all four studs cut through/sheared on a dealer full restoration and the rider was very lucky to keep the bike upright and not total it![]()
Watch out for this issue!!! When it happened to the guy above, a number of my clubmates inspected their own bikes and found them to be using shallow dome nuts and thin washers too. The experience of one has resulted on a number changing their assembly to ensure that the nut tightens fully before bottoming out.
Checking that nuts are tight is not enough... tight against what?!
Post by MK Monty » Mon Jan 02, 2017 11:24 pm
After loosing 3 studs and almost the 4th I would bin the hub. I know we all want to fettle the life out of the ruddy things but you only have for studs holding your wheel on, not nice when they let go.
