Post by Nbowe » Wed Dec 28, 2016 12:28 am
Have fitted a mec Eur crank to a gp150 casing.i have a standard Beedspeed 190cc iron barrel and piston top end. I understand that the big end is shimmed on these cranks but do I need to shim the small end. There does seem to be quite a bit of play at small end when piston is fitted.
HxPaul wrote:If there is room for a longer small end bearing MB and Cambridge Lambretta sell a Yamaha 16x20x22 small end bearing to fit a Lambretta and it stops the movement that you get with the original bearing on the gudgeon pin.The standard original one is 16x20x20.
dickie wrote:HxPaul wrote:If there is room for a longer small end bearing MB and Cambridge Lambretta sell a Yamaha 16x20x22 small end bearing to fit a Lambretta and it stops the movement that you get with the original bearing on the gudgeon pin.The standard original one is 16x20x20.
The ones I'm talking about still had about 4mm (total) float with a 22mm bearing.
johnnyXS wrote:I think you're missing the point paul![]()
It depends on the piston that you are fitting. You need to measure the piston casting then decide if piston shims are required depending on the crank being used
Nbowe wrote:The big end is shimmed so no movement there. The small end bearing and Conrod measure 20mm and the gap in the piston casting is 24.5mm so about 2.25mm movement either way. The Conrod doesn't travel that far but the bearing does. Mb site doesn't really convince me either way on wether I should shim it or not
You could do worse than research the (very) old Lambretta recommendations. However, a bit more recently, A. Graham Bell advocates critical clearances:
Big end 0.5 to 0.6 mm (0.020 to 0.024”)
Little end (shake) 0.8 to 1.3 mm (0.031 to 0.051”)
I hope that helps.
