Help needed - fitting stand!!
Postby Hammer » Mon Dec 26, 2016 7:21 pm
I am trying to fit my stand to a series 3. Rather than fit the stand and then add the spring last I am trying to assemble it with the spring attached and then bolt the whole lot up. Problem is I can't get the bolt right the way through the cross member because the spring is holding it off!! Any help or tips greatly appreciated.
Hammer
Re: Help needed - fitting stand!!
Postby MK Monty » Mon Dec 26, 2016 8:13 pm
Bolt the stand on without the spring then pull the spring on with the stand up. Its a shorter pull than with the bike sitting on the stand, you can do it spring on with the stand up and get the bolts in but you may need three hands.
MK Monty
Postby Hammer » Mon Dec 26, 2016 8:24 pm
Cheers MK, any tips on how to pull the spring? This one (Scootopia) feels very tough. Thanks in advance.
Hammer
Postby Phil D » Mon Dec 26, 2016 8:28 pm
As MK Monty said but a spring puller tool really helps
You can easily make one alternatively.
Phil D
Postby carlos fandango » Mon Dec 26, 2016 10:54 pm
or use the penny trick.
bend the spring and force pennies into the coils , cant remember how many you need ? 8 ish ?.... this effectively lengthens the spring and makes it easier to fit on the stand, do it in the up position. when you flip the stand down the pennies should fall out :)
carlos fandango
Postby CHRIS in MARGATE » Tue Dec 27, 2016 12:45 am
Do it with N/S rear runner off.
Easy then
Postby rossclark » Tue Dec 27, 2016 2:21 am
I never had any success with the puller or the pennies, only way I got it on was to fit the spring to the stand and the frame then work to get the bolts in.
Postby HxPaul » Tue Dec 27, 2016 10:30 am
I've always fit them as Chris says.I take the non kickstart side runner board off,then fit the spring on the stand,you will have to lean the stand slightly to the nearside to fit the spring,once its fitted stretch the spring by moving the stand so that it lays on the cross member,but still keep the stand up and fit the bolts through the strengthening peice,cross member and hooks.
Postby Hammer » Tue Dec 27, 2016 10:30 am
Thanks Ross, I think I might actually get longer 40mm bolts as opposed 30mm just to give me a bit of extra reach to get the nut on the threads so that I can wind it all up.
Hammer
Postby Hammer » Tue Dec 27, 2016 10:38 am
Thanks Hx Paul. I'm actually fitting the stand to a newly painted bare frame so no problem with the side runner. I am using your method (with the frame upside down to make it easier) but I just cant get enough of the bolt through the cross member to get a washer and nut on because the spring holds it off.
Hammer
Postby johnnyXS » Tue Dec 27, 2016 11:50 am
have you got a G clamp ?
or bolt the stand up with 40mm bolts then fit a couple of adjustable wrenches or mole grips to hold it in place so you can undo and replace the 40mm with 30mm bolts
johnnyXS
Postby HxPaul » Tue Dec 27, 2016 1:11 pm
Have you got the spring on the right way around.The spring should fit flat against the cross member.
Postby johnnyXS » Tue Dec 27, 2016 1:50 pm
HxPaul wrote:Have you got the spring on the right way around.The spring should fit flat against the cross member.
he can't come to the keyboard right now ...as he's got his hand jammed in the stand spring :lol: :lol:
johnnyXS
Postby CHRIS in MARGATE » Tue Dec 27, 2016 3:59 pm
There's always a wait at A&E this time of the year.
Postby MK Monty » Tue Dec 27, 2016 8:33 pm
I have a very chunky stainless steel version that I defy anyone to fit. I saw it glinting in the sun in the middle of a flower bed after it bit me and it was thrown as far away as possible. :mrgreen:
MK Monty
Postby Hammer » Tue Dec 27, 2016 10:01 pm
Thanks all. Got there in the end, used the pennies trick in the end and bolted all up together! :D
Hammer
Postby derbystu » Wed Dec 28, 2016 6:00 pm
This makes me feel a lot better about my own stand/spring issues - I'd put it down to my lack of mechanical skill until I saw this!
Over the last 3 years I've had problems getting the stand right - no matter what I've tried it just doesn't pull up near enough to the floor panels and it's a sod of a job to get the stand up & down. I've tried refitting it, using new longer bolts, new shorter bolts (even had some just snap), and a new spring. Improves for a short while then back to square one again. Watching others put stands up & down with a mere flick really cheers me up - reckon a new stand may be the only answer, but if that doesn't work then stuff it, I'll live with it!
derbystu
Postby mcbrid » Thu Dec 29, 2016 9:21 pm
You want to try putting the massive spring on an Orbar on!
To make it harder it stretches over the exhaust to a lug welded on the underside of the footboard!
:shock:
mcbrid
Users browsing this forum: Baidu [Spider], Google [Bot] and 69 guests
