EddieStone wrote:I'd go for 21 degrees BTDC. It was explained to me that modern petrol contains a high percentage of ethanol these days that burns much slower than petrol back in the day. Retarding your ignition takes account of this. I think I used 23 degrees on my Li.
Also the ethanol petrol burns at a much higher temperature and the retarded timing helps keep your engine cooler.
Post by grandpa » Wed Nov 23, 2016 12:02 pm
Hi Chaps
I have bought a jet 200 it has a sx200 engine with GP crank the cylinder has the SIL "S" symbol, electronic ignition ,dellorto PHBH26 carb and clubman exhaust.
What should I set the timing to?,SX 19 or GP21.I am in the process of converting it to dc.The timing appeared to be set at 25 degrees.I am using the positive stop method of determining the TDC.The engine starts and runs ok but its not ready yet for the road.
Thanks,
Grandpa
Personally, I always run my vehicles on the best fuel available whether petrol or diesel. So that equates to Tesco, Shell or BP Super unleaded for road scooters. I also advocate a large bleed (tailpipe) on the exhaust of Ø25 mm on a 200 to help the engine run cooler & contribute toward any desired over-rev.
Post by Phil D » Wed Nov 23, 2016 2:29 pm
Not that it really matters for a two stroke but I have given up using supermarket fuel in our family cars as a guy at work had a nearly new Golf Gti engine wrecked the engineer told my colleague not to use the stuff as he had lost count of the engines he inspected where poor quality fuel was to blame .
There was a case in South Wales where supermarket fuel was to blame(Tesco I think) for wrecking engines.
You pays your money you takes your chance!
Post by CHRIS in MARGATE » Wed Nov 23, 2016 8:25 pm
It was total folly to think there was ever any advantage or performance gain in using 105 octane petrol. Our beloved engines were designed to run on cheap petrol. Sadly that "cheap" petrol equates to what is now our dearest petrol which is available as 97 octane from BP Texaco Shell. Forget Tesco momentum 98 which is overloaded with additives. Lead plays no part in our conundrum and filling the tank with lead pellets is again, another folly. Lead was there to protect the valves and seatings on 4 stroke engines.
19 degrees is as far as I would ever retard on a statically timed standard or lightly tuned engine but I would want to see and record the timing point right through to maximum rpm.
A lot of these figures ( there are exceptions from trusted posters on here) come from people whose mate told them so, without any rationale and that is what they swear by.
Use a good timing disc, good TDC tool and strobe right through the rev range.
For me, 17 degrees is overkill and 6 degrees back from where it once was.
I am always open to change but show me quantifiable evidence first not just guesstimates.
CHRIS in MARGATE wrote: Lead was there to protect the valves and seatings on 4 stroke engines.
Post by Dazts1 » Wed Nov 23, 2016 10:06 pm
I read an interesting article a couple of years back in a ford pulication. Owning an old ford I read with intrest. All high octane petrols were tested by running a car up on the rolling road. Car then drained of fuel , refilled and run up again until all brands of fuel was tested. The fuel that came out on top was indeed Tesco's momentum. At the time I found it hard to believe, but it seems to keep coming out on top.
CHRIS in MARGATE wrote:From one of the Petrol head forums.
You will not notice a performance problem with Tesco's 99 RON unleaded. Badged as 'Tesco Momentum 99. But the fuel itself is a basic 95 RON unleaded fuel laced with bioethanol to a maximum of 5% by mass. Ethanol is very good at inhibiting pre-ignition as it does raise the Research Octane Number of the fuel to which it is added. Tesco's petrol is produced by Greenergy. Or, at least, most of it is.
Read more at: http://www.torquecars.com/forums/thread ... uel.15673/ - © TorqueCars.com
Still just opinions I'm afraid.
