TS1 240 Not well
TS1 240 Not well
Postby Freight10 » Mon Nov 07, 2016 11:14 pm
Hi all, after some opinions please..
I recently had my TS1 240 engine rebuilt, the engine casing needed a small amount of welding around the head stud holes...sorted..
I had the barrel re honed, head skimmed and the gasket profiled to match perfectly.
New bearings, seals, gaskets etc etc.... ran like a dream, very responsive, sounded fantastic...I was over the moon...
Anyway, on the way to Brid, 35 miles approx., pulled in to a garage for a much needed smoke break and refill of fuel.
roughly 20 mins later, tried to start it...nothing, tried again and a strange squeaking noise is coming from the engine, every time I kick it over the same awful noise and no attempt at firing..
Luckily my wife was kind enough to bring me out a spare scooter and a great weekend was had...I haven't had time to strip the engine yet, so I just wondered if anybody has any ideas what could possibly have happened when standing still in a garage with the engine turned off... :? :? :?
Thanks in advance
Trevor
Freight10
Re: TS1 240 Not well
Postby Warkton Tornado No.1 » Mon Nov 07, 2016 11:35 pm
With respect to the welder, Lambretta crankcases can be a sod to weld.
The alloy comprises zinc to help the casting process, which results in porosity. Then there’s the two stroke oil that will be ingrained.
Then the welding itself can so easily set up stresses that relieve themselves after a bit of heating & cooling.
So sorry, but I’d suspect the squeaking as a 'whistle' due to an air leak.... :(
Postby Freight10 » Mon Nov 07, 2016 11:42 pm
Thanks for the advice, I will attempt a leak test before I start ripping it down...losing heart a bit now with it, brought the engine as a running lot...all together I think its covered a mere 50 miles (that's being generous) and a total of £2200 ..... :evil:
Freight10
Postby Scooterlam » Mon Nov 07, 2016 11:51 pm
don't get too down, could just be the head come loose.
you were going to re torque the head anyway.
Scooterlam
Postby Freight10 » Mon Nov 07, 2016 11:54 pm
fingers crossed... :)
Freight10
Postby Scooterlam » Tue Nov 08, 2016 12:49 am
positive vibes. its what tuned scoots run on.
Scooterlam
Postby xenia1 » Tue Nov 08, 2016 7:17 am
Even with a slightly porous weld you would still get some fuel and air into the cylinder and there would still be compression, it would at least show some form of life kicking it over. The loose head suggested by Derek (Scooterlam) is the more likely culprit...hopefully.. ;)
xenia1
Postby Toddy » Tue Nov 08, 2016 7:22 am
I would say Head loose with the Squeaking noise , dont get down matey least you got there and enjoyed Brid :D
Postby EddieStone » Tue Nov 08, 2016 11:12 am
The only time I've heard squeaking from a Lambretta the head needed re-torqueing. Most likely culprit after a rebuild.
Could be the stud pulling out of the crankcase as well, so it would be wise to check that.
EddieStone
Postby Freight10 » Tue Nov 08, 2016 3:55 pm
Thanks guys appreciate the feedback... I will give it a go the weekend and let you know how I get on.
Freight10
Postby CHRIS in MARGATE » Tue Nov 08, 2016 5:24 pm
OK I'm going for another root cause. Flywheel parted company with the boss or possibly woodruff key sheared.
These are "awful" squeaking noises.
Postby Adam_Winstone » Tue Nov 08, 2016 6:35 pm
^... I too wondered about the ignition, woodruff or crank side of things.
Postby Strummer10 » Tue Nov 08, 2016 7:42 pm
Probably not the issue as i'd agree sounds like a loose head issue..........., but just thought i'd throw this in.
We had a squeaking noise coming from the cylinder on a GP this summer (same noise you get with a blown head gasket or loose head). After stripping the cylinder and 'flushing down' the cylinder and head faces and re- 'threebonding' the base gasket and cylinder head it was still squeaking. Eventually we found it to be a bent conrod ??
Strummer10
Postby compass » Tue Nov 08, 2016 7:49 pm
CHRIS in MARGATE wrote:OK I'm going for another root cause. Flywheel parted company with the boss or possibly woodruff key sheared.
I helped strip an engine down in a German garage last year due to symptoms above (not mine) , only to find head , barrel and piston all good. It was indeed the flywheel trying to part company. From now on will always check flywheel first :roll:
compass
Postby Scooterlam » Tue Nov 08, 2016 10:51 pm
Lots of things to check, start with the easiest first just getting someone to kick it over while you listen can save loads of time.
personally I would give it two coats of "looking at" before I dropped it and started stripping.
Scooterlam
Postby Freight10 » Fri Nov 18, 2016 1:09 pm
Just a quickie... haven't yet had time to look at the scooter, work is a bit mad, but I haven't given up and I will feedback the results when I eventually get round to it...thanks again.
Freight10
Postby Freight10 » Fri Nov 18, 2016 7:54 pm
Ok, well finally checked the engine...full marks to you all that suggested the head bolts. ..
All 4 were finger tight at best with one stud having come completely out of the barrel when tightening.
I've spoken to a friend today who is going to fit a helicoil to hold it in properly...
Thanks again guys really appreciate your help...
Freight10
Postby Adam_Winstone » Fri Nov 18, 2016 8:56 pm
Well done for getting it sorted.
Postby CHRIS in MARGATE » Sat Nov 19, 2016 12:11 am
I'm going back to crocheting !!
Well done. And especially thanks for following through with feedback.
