series 3 front mudflap
Postby peejay » Thu Oct 20, 2016 6:24 pm
this design has proved very successfull in keeping most debris away from cables and wiring loom under the front mudguard
the one shown here is actually 100mm longer than the template above, while on the move it tends to protect the electrics of the foot brake
made from 2mm thick rubber it's simply fixed to the four longer mudguard bolts using penny washers to spread the load
even this very long version hardly notices when parked up
Re: series 3 front mudflap
Postby Tractorman » Fri Oct 21, 2016 9:22 am
Looks good for a winter mod on the series 2.
Postby EddieStone » Sat Oct 22, 2016 5:38 pm
This isn't the modern way! Surely you should be getting a load made for thruppence and flogging them for 25 quid a pop?!
Thanks for the info, looks very self, especially as i don't use a splashguard. Where did you get the rubber from?
EddieStone
Postby peejay » Sat Oct 22, 2016 11:45 pm
Tractorman wrote:Looks good for a winter mod on the series 2.
hi David
only slight mods needed to fit it to S2 or S1, i've done it but don't have a template for it
Postby peejay » Sat Oct 22, 2016 11:52 pm
EddieStone wrote:This isn't the modern way! Surely you should be getting a load made for thruppence and flogging them for 25 quid a pop?!
to be honest i just can't be assed to take orders and bother with postage etc but if you really want one for £25 i suppose i could do one :)
rubber is 2mm thick and bought from Portmere Rubber company, Southampton. i think they have other branches
Postby Tractorman » Sun Oct 23, 2016 8:23 am
hi David
Thanks peejay, I will should be able to work it out, I have all winter ;) ;)
