Scootopia mounts
Posted:
Sun Oct 16, 2016 10:35 am
by pat12966
HI, they were fitted to a standard innocenti GP 200. They were new so, I left them on .I had the engine rebuild & then last week when I went for a ride for the first time, I did not go over 45mph as the vibrations were too muchi! It was horrible to ride & I could not wait to get home. I have now replaced them with uni 3 hole mounts, it has transformed the scooter
Re: Scootopia mounts
Posted:
Sun Oct 16, 2016 10:54 am
by HxPaul
pat12966 wrote:HI, they were fitted to a standard innocenti GP 200. They were new so, I left them on .I had the engine rebuild & then last week when I went for a ride for the first time, I did not go over 45mph as the vibrations were too muchi! It was horrible to ride & I could not wait to get home. I have now replaced them with uni 3 hole mounts, it has transformed the scooter
Read this
http://www.scooterotica.org/forum/viewt ... ine+mounts
Posted:
Sun Oct 16, 2016 11:04 am
by Tractorman
I had mine on for 15 miles and changed them.
Posted:
Sun Oct 16, 2016 3:28 pm
by burnside
Had mine on for 2k miles, they improve a lot after around 500 miles. I tend to get most vibrations at around 45-50 mph, but over that speed don't feel any
Posted:
Sun Oct 16, 2016 4:21 pm
by Tony Hart
As above. They seemed to sort themselves out after about 500miles on a Mugello 186 engine
Tony
Posted:
Sun Oct 16, 2016 5:41 pm
by Tractorman
Perhaps the vibrations alter the molecular structure of the rubber
Posted:
Sun Oct 16, 2016 5:50 pm
by Tony Hart
Tractorman wrote:Perhaps the vibrations alter the molecular structure of the rubber
Or my a**e has become numb to the sensation
Posted:
Mon Oct 17, 2016 8:57 am
by xenia1
Any type of rubber mount whether engine/ gearbox/ two/ four wheels goes softer with age and use, the scootopia mounts would most likely have been fine after a few hundred miles or so and with their harder compound will also most likely outlast others with a softer make up..
Posted:
Mon Oct 17, 2016 9:10 am
by Tractorman
xenia1 wrote:Any type of rubber mount whether engine/ gearbox/ two/ four wheels goes softer with age and use, the scootopia mounts would most likely have been fine after a few hundred miles or so and with their harder compound will also most likely outlast others with a softer make up..
You could corner the market by selling bedded in scootopia engine mounts
Posted:
Mon Oct 17, 2016 9:32 am
by burnside
Tractorman wrote:xenia1 wrote:Any type of rubber mount whether engine/ gearbox/ two/ four wheels goes softer with age and use, the scootopia mounts would most likely have been fine after a few hundred miles or so and with their harder compound will also most likely outlast others with a softer make up..
What mounts are you using on your combo? I'm using the RLC sidecar mounts, now that are super hard and vibrations are mental with these, I did fit some bubble grips which have helped but I would struggle to ride any real distance....but maybe these will settle after a few thousand miles
Posted:
Mon Oct 17, 2016 11:27 am
by pat12966
I am using scootopia mounts as paper weights,i don't thing my teeth bum hands arms could wait for 500 miles
Posted:
Mon Oct 17, 2016 4:24 pm
by Tractorman
burnside wrote:Tractorman wrote:xenia1 wrote:Any type of rubber mount whether engine/ gearbox/ two/ four wheels goes softer with age and use, the scootopia mounts would most likely have been fine after a few hundred miles or so and with their harder compound will also most likely outlast others with a softer make up..
I use the AF double on the r/h side and a SIL one on the left. I had thought about the RLC when I change but am pleased with your feedback.
Posted:
Wed Oct 19, 2016 9:43 am
by Kev Fox
Fitted Scootopia engine mounts to my SX. The vibration was noticeable instantly. Have ran it for 700 miles now and they are shaking my scooter to bits. I have ran it hoping they would improve with time but sadly not. Scooter is apart now for a refurb and those mounts are coming out.
