Fork straightening
Fork straightening
Postby Wack » Sat Oct 15, 2016 10:07 am
Does anyone know where I could get some forks straightened on the stem ? I know Grand Prix in Leicester used to do them but has now closed I believe.
Re: Fork straightening
Postby bike grim » Sat Oct 15, 2016 10:11 am
Frank Sanderson. You can post them to him in Galgate. Pm me if you want his number.
Postby Digger » Sat Oct 15, 2016 10:53 am
Also Mike Phoenix.
Digger
Postby Adam_Winstone » Sat Oct 15, 2016 11:15 am
I need some doing too so welcome the info. Ta
Postby ToBoldlyGo » Sat Oct 15, 2016 11:48 am
Friend of mine in Tewkesbury has a jig for straightening them. Depends where you are really.
Postby Wack » Sun Oct 16, 2016 9:30 am
Thanks for the replies, I've had a frame done at Mike's but he's a long way away from Lincolnshire so it would be good to find someone a bit nearer if possible?
Postby HxPaul » Sun Oct 16, 2016 9:36 am
Wack wrote:Thanks for the replies, I've had a frame done at Mike's but he's a long way away from Lincolnshire so it would be good to find someone a bit nearer if possible?
Give Lincs.Lambrettas a ring,they may do fork straightening,if not they might know someone that does closer to you.
