Scouse Scooterboy wrote:Are they a massive improvement on the original drums?
Post by Knowledge » Thu Oct 13, 2016 4:03 pm
I would say that a well set-up drum and a well set-up (cable operated) disc were of similar performance. To get the best out of any disc brake, you need the mechanical advantage of hydraulic operation.
Some years ago, someone unearthed a quote from Innocenti who described the need that drove the introduction of the original disc brake (the first one ever to be fitted to a production two wheeler) as the fact that the drum brake could lock too easily when you pulled the lever. This makes you think that if the disc brake was less easy to lock, then perhaps it was not as good at stopping you. Or is that me being cynical?
Warkton Tornado No.1 wrote:
However, with advances in materials & knowledge(!) regarding optimising the disc brake (disc pads, cables) I think they can be made to work very well with substantially more feel than a reverse pull drum.
One thing I do agree with is that there will be mechanical losses is the semi-hydraulic set-ups.
Post by dickie » Thu Oct 13, 2016 6:03 pm
Ive got reverse pull drum and while it's very effective I don't think I've ever used a brake with such poor feel.
And while I know you're right about semi hydraulic set-up I still hope you're wrong as I've spent a bloody fortune on one for my current project.
However, in all honesty, & I’m judging you as having sound engineering principles from your other recent response about fork springs.....
I’m curious to know what made you select that type
Post by dickie » Fri Oct 14, 2016 2:58 am
Pure vanity. I think master cylinders and outboard discs just look too modern for a series 2.
And yes from an engineering point of view it's a poor decision but then again, so is owning a 50 year old 2 stroke when I can get a perfectly decent sv650 for quarter of what this is costing me to build. Oh well.
HxPaul wrote:I use Newfren sintered pads in mine,stopping power is great.You can buy them from most good Lambretta dealers.
citydaz wrote:how often do you need to replace pads?
Im a bit of a digital rider - all on or all off.
Post by Rich Oswald » Wed Oct 26, 2016 10:56 am
With sintered, probably a little bit more often than with standard as they are softer compound but how long depends on type of use,
However, I can’t imagine why Newfren pads would be vastly different to any of the various pads I have in ‘stock’..
