Warkton Tornado No.1 wrote:I’ve just trawled t’internet & opinion varies on bike forums.
There are opinions on having a low C of G or lower un-sprung weight, which are obviously opposite to one another.
TBH, I doubt there’s any noticeable difference in either way, but it would be best to have the pair with the same orientation
HxPaul wrote:I have to take issue with you on your last statement,I rode a scooter in the sixties and I can asure you that you didn't have to keep one eye on the road looking for potholes.
dickie wrote:HxPaul wrote:I have to take issue with you on your last statement,I rode a scooter in the sixties and I can asure you that you didn't have to keep one eye on the road looking for potholes.
It's not about potholes; you're f#cked either way on that one. Unless you want to fit trials bike suspension and 21" wheels. It's about the lower amplitude variations on the surface which modern Road laying techniques have massively reduced.
Digger wrote:Modern road laying techniques?
Scrape the top off and throw a bit more tarmac on?
grandpa wrote:Hi Egee,
You could make a fork spring compressor."Heres one I made earlier"
viewtopic.php?f=10&t=144&p=538&hilit=fork+spring#p538
I agree with HxPaul,I don't remember having to watch out for potholes in the mid sixties going to work on my NSU Prima and later a TV175.Speed and traffic density was much less,a Ford Anglia would not do much more than 70mph.Wet manhole covers could catch you out though.
Grandpa
I don't really need a Lambretta as I have a bus pass
HxPaul wrote:I fit the large buffers top and bottom to prevent the front end diving as far under heavy braking,under normal riding conditions they dont tend to make a lot of difference (unless you hit a large pothole)The progresive springs do give a slghtly firmer ride but dont seem to compress to far over slight undulations in the road.As for the front shockers,there slimline after market shockers and they seem to do a good job of smoothing the ride.Making a fork compressor is a great idea,but you need all the parts to build it.The compressor I bought cost £15 and works as it should.
JETEX wrote:If I could just add my view....... ?. I put my fork springs in with the close coiled bit to the top. The reason being that you get 'soft' springing over undulations, but you hit the firmer part of the springs when going over rougher ground.
Users browsing this forum: No registered users and 93 guests
