Saving Stickers
Saving Stickers
Postby Bilko » Thu Sep 29, 2016 3:07 pm
I've a couple of stickers on my GP that I don't want to lose as there no longer available.
Is there any way of saving them. Would a hairdryer and gently lifting it work?
Bilko
Re: Saving Stickers
Postby terryj » Thu Sep 29, 2016 3:16 pm
pretty sure you can buy something called sticky stuff remover believe wd 40 also works
https://www.amazon.co.uk/s/?ie=UTF8&key ... zucwz253_b
hot gun as well
https://www.youtube.com/watch?v=ewFCpuEnIAs
terryj
Re: Saving Stickers
Postby EddieStone » Thu Sep 29, 2016 3:16 pm
I've taken stickers off using a hair drier but the stickers didn't survive, they tend to stretch and break.
You could try lifting one end and soaking in lighter fluid. Keep lifting it bit by bit while soaking in lighter fluid. Maybe practice on something less precious first?
Acetone might work but you could lose the ink on the sticker as well. You'd definitely lose the paint.
Alternatively, take a photo of them and get some more made.
EddieStone
Re: Saving Stickers
Postby AlG » Thu Sep 29, 2016 3:23 pm
First step is definitely take high definition digital photos which could be reproduced if all else fails.
I have managed to lift the metal foil stickers before with gentle heat from a hairdryer, but never really succeeded with thin vinyl. Sticky Stuff remover in my experience only really removes the remaining residue.
AlG
AlG
Re: Saving Stickers
Postby dickie » Thu Sep 29, 2016 8:02 pm
The glue on stickers tends to leach the plasticisers from the vinyl making them brittle.
You can keep them young by applying certain types of oil and leaving to soak in, but it takes years to rejuvenate them.
A bit like oil of olay. Except it works.
Plus i don't know which oils help.
Re: Saving Stickers
Postby Bilko » Fri Sep 30, 2016 9:07 am
Thanks for the replies. appreciate it.
Bilko
Re: Saving Stickers
Postby carlos fandango » Fri Sep 30, 2016 12:01 pm
Try heating the panel from behind , with a hair dryer or hot air gun , so heating the glue up before the actual sticker :)
carlos fandango
Re: Saving Stickers
Postby missing lynx » Fri Sep 30, 2016 12:16 pm
if you take a quality digital photo a friend of mine can re-do the sticker he trades under the name of The cool graphic he's done some for me and they're spot on and uv stabilized
Re: Saving Stickers
Postby Bilko » Fri Sep 30, 2016 4:25 pm
Thank you both.
I'll get my daughter to bring up her hairdryer tomorrow. I can't find the one Andy Vass left behind. His curling tongs are still here though.
Bilko
Re: Saving Stickers
Postby Leotech » Fri Sep 30, 2016 5:46 pm
You can buy thick sticky back plastic, they use it to make graphics for MX bikes,
If you stick it over stickers, get it stuck down good then use a bit of heat to pull the lot off 9 times out of 10 the sticker will come away with the thick stuff...
Leotech
Re: Saving Stickers
Postby piskie » Mon Oct 03, 2016 3:30 pm
Its so long since I've seen ya bilko the straightners and hairdryer are now surplus to requirements
piskie
