No clutch !
No clutch !
Postby Vmakgp » Tue Sep 27, 2016 12:15 pm
Hi chaps fitted engine into my dl/Gp after complete strip & upgrade , Gt crank, Gt 186 kit 30 MM delorto , Franspeed s/s super tour exhaust & Bgm super strong clutch wired up the casa Tronic ignition put some juice in her & fired it up , sounds lovely , pulls clutch in put her in first & just jumped n stalled no clutch adjusted cables & arm but nothing .
Fitted clutch shim , & bronz fimble plates all soaked in oil , could it need shimming out to Ingage the fimble ??? Anythoughts ??
Vmakgp
Re: No clutch !
Postby Knowledge » Tue Sep 27, 2016 1:25 pm
The answer might be yes, but may I ask a couple of basic questions? Can you see the clutch arm moving? Is it moving enough?
The arm might be on the wrong position on the splines.
(Best to check this before opening up the casing again)
Re: No clutch !
Postby Vmakgp » Tue Sep 27, 2016 2:45 pm
Hi set the arm up at 90 digrees and there s around an inch of movement tride moving arm and adjusting cables no joy ' fimble was on , looks like taking casing off !! :roll:
Vmakgp
Re: No clutch !
Postby Knowledge » Tue Sep 27, 2016 4:17 pm
Yup. Sorry. However, these things never take as long as you think (well, sometimes)
Re: No clutch !
Postby Meds » Tue Sep 27, 2016 5:45 pm
It might be an idea to manually test the clutch operation to see if it is compressing.
That should tell you if it's the linkage/cable set up or the clutch it's self.
Meds
Re: No clutch !
Postby Vmakgp » Tue Sep 27, 2016 6:24 pm
Yep will try n manually test the clutch meds ' apparently there should be Upto 2mm of clearance in the plates when clutch is compressed , will have to work out how much the fimble compresses the clutch first that shouldn't be to difficult !
Vmakgp
Re: No clutch !
Postby HxPaul » Tue Sep 27, 2016 7:13 pm
GP engines dont have a clutch thimble,they have a bronze pressure pad.
Re: No clutch !
Postby Vmakgp » Tue Sep 27, 2016 7:31 pm
I'll stick with my discription thanks as you understood the part I was referring to Hx '
Vmakgp
Re: No clutch !
Postby HxPaul » Tue Sep 27, 2016 8:06 pm
Ok.Only just trying to help.
Re: No clutch !
Postby Vmakgp » Wed Sep 28, 2016 5:49 pm
Well spent the whole day stripping &fetling the Bgm super strong clutch wile relaying results through emails to Philipp at Bgm in Germany ,when the clutch is fully compressed to allow the plates to separate the springs both sets medium & hard become coil bound and the inner basket and compression plate still turn the outer back sprocket , Philipp said that they now supply the clutch with hardened shims as some shims had been bending when the clutch nut was fully done up , after taking measurements from the inside of the pressure plate to the inside of the basket face were the springs sit I believe it's a case of the basket not being deep enough & or the pressure plate , and when it's compressed they are binding together I suppose I could try 1 MM steels and shorter springs but when a clutch costs upwards of 340 quid ya would expect it to work , I will try the shim Philipp has shipped free of charge then take it from there .
Vmakgp
Re: No clutch !
Postby gaz_powell » Wed Sep 28, 2016 6:21 pm
Is the clutch supplied as a complete unit ; sprocket, spider, plates, springs etc ??
Re: No clutch !
Postby Vmakgp » Wed Sep 28, 2016 6:37 pm
Yes Gaz springs , 1.2 MM steels , plates , sprocket , basket , pressure plate , with 2 threaded holes to compress it , I could put 1mm steels in that would give an extra 1mm clearance but would you be able to compress the Ten springs enough with the leaver .
I've sent Philipp a pic of the springs as asked , as they shouldn't be coil pound !
Vmakgp
