Sat nav powering problems
Postby TS1-200 » Mon Sep 26, 2016 4:25 pm
Had a problem with my new sat nav going and coming back from Wooly over the weekend, it suddenly switched off as the battery had run down, I have powered it with a mod charger, it was ok for a few hours, but then switched off, now would a mod charger give enough power for the sat nav with your headlights on ? if not what would be the best way to power it,I don`t really want to fit a battery, was thinking of a 5 pin regulator and connecting the DC from that to the sat nav, if so would I need to fit anything else ?
TS1-200
Re: Sat nav powering problems
Postby Knowledge » Mon Sep 26, 2016 7:20 pm
You have already provided the best answer: a battery.
Don't be too quick to dismiss this idea, as even a small burglar alarm battery will do the trick and can be very easy to hide, as they can be mounted at any angle except upside down.
There is a very useful PDF fact sheet on the Yuasa battery website.
Postby MickYork » Mon Sep 26, 2016 7:55 pm
The Mod charger should have been ok, but it's all dependant on what size lamps you're running.
I agree a battery is the best solution but maybe upgrading to lower wattage (power) LED lights would also help.
Postby coaster » Mon Sep 26, 2016 8:33 pm
I wondered where my reply had gone then realised I'd responded over on Scooterotica :roll:
That would depend on the wattage of your headlamp and iff you are also using an LED rear lamp. The power available from an Indian stator is very marginal and if you are using a 55/60 watt headlamp you will struggle and won't have enough power for the satnav at town riding speeds. You should be ok with a 35 watt lamp though. The |BGM stator puts out a bit more and mine charges at 13 volts around town rising to 14.2 volts from about 40mph. That's with a 35 watt rated HID headlamp and a BGM led rear lamp. I charge a 7.2 Amp battery and power a Garmin, satnav, Iphone etc.
Postby ian i.o.w » Mon Sep 26, 2016 9:20 pm
Hi mate I run my phone sat nav and lights on using a mod charger all good no probs but did lose signal going put it down poor reception .I used to find usb adapter some times came out of mod charger lead taped together all good now ,maybe this happened ,stopped charging and wore battery down
ian i.o.w
Postby TS1-200 » Tue Sep 27, 2016 11:19 am
Thanks for your help lads, so what would be the best way to connect up the burglar alarm battery and sat nav
TS1-200
Users browsing this forum: Majestic-12 [Bot] and 92 guests
