clutch
clutch
Postby JBG584 » Mon Sep 12, 2016 8:18 pm
Hi
Went on the I.O.W rally but had trouble with clutch because of the volume of scooters I had to keep the clutch in for long periods but I found it then wouldn't dis engage so couldn't change gear and then kept trying to move although clutch in .I had to keep putting it into neutral quickly but once I was going when I left the pack it was fine.This is a fairly new complete unit.Any ideas Ray
JBG584
Re: clutch
Postby Marty ULC » Mon Sep 12, 2016 8:36 pm
Could it have overheated and the corks swelled?
Marty ULC
Re: clutch
Postby missing lynx » Mon Sep 12, 2016 8:57 pm
it could be a combination of the clutch overheating a bit and if the clutch is a bit heavy your grip weakening with the effort of having to over use the clutch making it harder and harder to pull in fully
Re: clutch
Postby Warkton Tornado No.1 » Mon Sep 12, 2016 10:45 pm
I think that many people forget that as the clutch beds in/wears, the centre bell moves closer to the side case. As a consequence, the cable needs slackening to avoid drag.
For that reason, the cable adjuster should be set so that it is ‘central’ when a fresh clutch is installed, thus allowing either slackening or tightening.
I hope that makes sense :)
Re: clutch
Postby JBG584 » Tue Sep 13, 2016 2:13 pm
Hi
thanks for info will check out slack etc.
JBG584
Re: clutch
Postby coaster » Tue Sep 13, 2016 3:23 pm
You didn't mention if this is a standard set up or a 5 plate jobbie. Also, balloon type grips reduce the amount of pull, worth considering if you have them as well as play in the lever pivots.
Re: clutch
Postby burnside » Tue Sep 13, 2016 4:26 pm
IOW ride out is a clutch killer, I did it a few years ago and my clutch dragged nearly all the way round but was fine afterwards and until it finally gave up the ghost a year later, won't both doing that again!
burnside
Re: clutch
Postby JBG584 » Sun Sep 18, 2016 11:52 am
all standard clutch and grips.thanks for help.
JBG584
Users browsing this forum: No registered users and 99 guests
