Post by Patricks3179 » Fri Sep 16, 2016 12:53 pm
Hi thanks for the reply , I've got the layshaft as tight as I can get it with the m&b sleeve puller , I've not put on the hub nut yet , as regards to the gear cluster shim I thought you only had one standard size ?
Users browsing this forum: No registered users and 83 guests
