Exhaust
Exhaust
Postby Snelson1137 » Tue Sep 06, 2016 8:48 pm
Any one no how to fit a evo tsr exhaust to a series 2 with out cutting the floor board
Snelson1137
Re: Exhaust
Postby Toddy » Wed Sep 07, 2016 6:21 am
I think you may struggle to fit any expansion pipe top a series 1/2 without trimming the rear board , You could buy another Rear Board to cut and use and save the original if you want to go back to a Standard pipe ?
Re: Exhaust
Postby bolzenanker » Mon Sep 12, 2016 4:43 pm
Sadly not, cut a slot for mine with a jigsaw.
bolzenanker
Re: Exhaust
Postby Donnie » Mon Sep 12, 2016 9:18 pm
Snelson1137 wrote:Any one no how to fit a evo tsr exhaust to a series 2 with out cutting the floor board
There is only one way to do that, dont fit the footboard. if you fit it, you'll have to cut it.
Donnie
Re: Exhaust
Postby Stevepshipley » Tue Sep 13, 2016 7:42 am
Toddy wrote:I think you may struggle to fit any expansion pipe top a series 1/2 without trimming the rear board , You could buy another Rear Board to cut and use and save the original if you want to go back to a Standard pipe ?
I did exactly that, cheap option from Buzsolomoto
Stevepshipley
