Storkfoot wrote:Have you uprated springs on that scoot? What dampers, if any?
roli150lam wrote:What tyre pressure is in the front tyre.
davet wrote:Have had the same on zippy and twist. This Euro was the most uneven wear. I'm sending it of to Continental to see if they can explain it. Nothing wrong with tyres otherwise and have always used conti's for last 15 years. Will let you know what they say.
Storkfoot wrote:My MOT man says it is too firm front suspension causing the front end to "skip". Your set up seems to disprove this. However, I suppose too much weight on the back would also cause skipping??
I have had this on a few different front tyres not just continental.
Captain Pugwash wrote:Block tread tyres wear the front edges off the block tread of the front tyre under breaking more than the rear of the blocks.
A front tyre doesn't carry the weight or riding stress of a rear tyre, but when the front brake is applied on any scooter with a better than standard brake the front of the blocks (as the front tyre contacts the road under breaking) will grip more than the rear of the block tread causing it to scrub off the front edge of the blocks when the trailing edge can't.
And better than average brakes exaggerate this wear.
Tyre pressures will Also contribute to this type of wear but it is not the sole cause.
I've always had this with block tread tyres whichever make I've fitted to the front wheel, my Dexters did the same so did the weatherman's, in my experience softer block tread wet weather tyres do this much more easily when ridden hard in the dry with a good front brake.
Rich Oswald wrote:I have had a thread up before about this and also a controvertial one on facebook. Nobody has come up with a suitable explanation for this apart from these tyres are crap. Oh and by the way it happened only on the front of mine when I used them, long , long ago. Someone even said they are like this from new which I think is total bollocks. These are pics from mine which I still have in the garage:-
