12 volt lighting
12 volt lighting
Postby stephena » Tue Aug 30, 2016 8:00 am
Still running a standard 6 volt points system only been out once in the dark and the lights are almost not worth having on.So is the 12 volt lighting conversion on this site as easy to do to do as it reads and does it give a similar light to a 12 volt complete ignition swap.I would like to leave it running on points are there any other options to improve the lights. Thanks Stephena.
stephena
Re: 12 volt lighting
Postby kennystag » Tue Aug 30, 2016 8:24 am
This is the easy one to do without going DC electronic ignition, witch in my opinion is the best way for good lights and horn.
cheers
Stag
http://www.ilambretta.co.uk/12v.html
kennystag
Postby Jono » Tue Aug 30, 2016 8:33 am
Great simple conversion that really works for low cost. I have 2 scooters both converted in this manner. To improve further have also fitted a battery to run brake light and horn off 12 volt DC via a mini-bridge rectifier.
Jono
Jono
Postby Meds » Tue Aug 30, 2016 9:07 am
Have a look at this thread
viewtopic.php?f=7&t=1709
The biggest issue I had was the dimming of the head light when the brake light /horn was operated.
I cured it using an LED lamp with a slight drop in the light output.
The simple answer is try it and see how it turns out
All you need is a vespa type regulator and some wire links.
Meds
Postby Jono » Tue Aug 30, 2016 7:30 pm
Hi mate
Meds - reply is correct and thread to information on prior posting should prove very helpful.
Personally I tried a LED rear/ brake light and although did help lighting the LED did not give bright illumination and was advised that they are not so good on AC current.
Now run conversion with 12 volt Alarm Battery supplying DC (loud)Horn, bright brake light and LED indicators.
Jono
Jono
