Jockeys headlamp
Can you use a 60/55 watt bulb in a Jockeys headlight conversion without melting the lens, please?
https://ilambretta.co.uk/forum/
Warkton Tornado No.1 wrote:Has anybody tried HID with a fluted glass lens?
I was wondering just how ‘bad’ it might actually be![]()
The alternative might be to obtain a Ø125 mm/5” glass lens from a spotlight & graft on to a Lambretta heat proof (non plastic) reflector. Does anybody know of where such an item may be acquired, please
MK Monty wrote:Warkton Tornado No.1 wrote:Has anybody tried HID with a fluted glass lens?
I
The standard lambretta reflector is like a coolies hat it's very crude compared with a modern headlight and the flutted lens is to give a glow rather than a beam. Any modern light is focused on the filerment of the lamp like a mag light can be focused to give a sharper beam. The JB fits and is a good solution for the price, if you are not worried about the none standard clear lens
Post by Digger » Tue Aug 30, 2016 8:51 am
Looks quite good in my opinion.
