Ser 3 LI150 6v Standard
Postby sp1v » Mon Aug 29, 2016 4:32 pm
Hoping someone can help. Everything original, bike running fine until I put lights on then splutters and back fires but as soon as I turn the lights off again bike runs fine again. Also no rear brake light whilst main lights on but brake light works when they're off.
Battery model but no battery fitted also running original regulator could one of these be the issue although as far as I can work out battery there only for parking lights?
sp1v
Re: Ser 3 LI150 6v Standard
Postby Warkton Tornado No.1 » Mon Aug 29, 2016 4:53 pm
You shouldn't run your set-up without a battery.
Otherwise, the problem is a classical symptom of your flywheel needing re-magnetising.
Last time I had one done, it cost a fiver @ Grand Prix Scooters in Leicester, but there should be dealers that still offer this service. I have no idea as to whether Grand Prix exists now, as Phil was trying to sell the business...
Postby sp1v » Mon Aug 29, 2016 5:09 pm
sp1v
Postby Adam_Winstone » Mon Aug 29, 2016 8:25 pm
Close up the spark plug gap and try it again.
As already stated, this is the classic symptom of a flywheel that needs to be remagnetized, however, the above 'close the plug gap' is the typical 'make do' fix. Getting the flywheel remagnetized is the thing to do but you might find that closing the gap is sufficient to see you through to the end of the rally season, then you can send the flywheel away (AF Rayspeed and others will do this for little money) over the winter.
Postby sp1v » Mon Aug 29, 2016 8:37 pm
Thanks Adam
sp1v
Postby Bird150 » Tue Aug 30, 2016 5:52 pm
HI Can enybody help,have just finished a rebuild but have a problem with the lights when I put the lights to main beam the running bulb will blow 12v and headlights will not work ?.Lambretta 150s.thanks Tony
Bird150
Postby sp1v » Tue Aug 30, 2016 8:07 pm
Tony sorry I can't help but you may get a better response if you place a new post mate
sp1v
