Colin
PS, I think the Atomic would clear the frame on a normally sized barrel, its just that the Avanti is a bit bigger.
missing lynx wrote:I've used offset cones for years and never had an issue with them moving out of position
Digger wrote:The only caveat I would add is make sure you get them from a reliable source]
coaster wrote:So no need to secure the cones in the frame?
Storkfoot wrote:Just to balance this, I tried a reputable set once. Never again. Moved repeatedy. I sorted my issue with a dremel on the manifold though and standard cones.
byron wrote:I've got a set of offset cones you can have foc Colin.
they would really be a last resort fit for me.
dare you take any more off the inlet...?
coaster wrote:Digger wrote:The only caveat I would add is make sure you get them from a reliable source]
I have an ebay pair on their way but who would be a reliable source? I gave up with the Beedspeed site as it wouldn't let me select a method of paymen
Storkfoot wrote:Have you tried the shock off your other scoot? (Don't tell me that's an R1 too?)
Digger wrote:[................Corrado was my saviour.....
