Dropped kick start
Dropped kick start
Postby Chilli » Tue Aug 16, 2016 7:33 pm
Just back from a disappointing ride out, I could hear a strange noise coming from the engine, so I pulled over and noticed the kick start was sagging, after some running repairs of the very temporary kind I managed to kick it and tie the kick start up with a throttle cable to get me home, bike rides fine but the kick start just sags to the floor, any ideas :oops:
Chilli
Re: Dropped kick start
Postby Warkton Tornado No.1 » Tue Aug 16, 2016 7:45 pm
The kick start spring has probably broken.
They do eventually, even if OEM.
It will be that or either of the two internal spring engagement holes....
Postby rossclark » Tue Aug 16, 2016 9:48 pm
Quite common for springs to rub on the top of the clutch and wear through til they weaken and break. Look for filings in your oil when you drop it.
