by eyeguy » Sat Aug 13, 2016 7:18 am
Hello All, I am trying to add the switch. I get the wires through with no problem. However, when i put the shaft in it causes a bind and the throttle will not turn easy. I've tried different positions to no avail.
Is there a trick here?
eyeguy
eyeguy
by Wack » Sat Aug 13, 2016 9:01 am
I try and make the wiring flat where it comes through the headset and smear with grease, but sometimes I thin the throttle rod down in a lathe.
by bazza3004 » Sat Aug 13, 2016 11:53 pm
Ive always used plenty of grease when doing this job , bit messy but seems to do the trick.
bazza3004
by byron » Tue Aug 16, 2016 11:51 pm
use wider sleeving, then the cables can spread out more around the throttle rod
byron
by eyeguy » Wed Aug 17, 2016 1:00 pm
Thanks to all, I did get it done. I separated the wires into to sleeves. And it worked. I may now do as Byron suggested.
Later
Eyeguy
eyeguy
