by tommy200184 » Thu Aug 04, 2016 6:42 pm
Hi, does anyone know a way to put the end of the spring in the hole....?
tommy200184
by Warkton Tornado No.1 » Thu Aug 04, 2016 7:54 pm
I’ve never owned any Spanish scooters, but I’ve copied the principal of the spring to close the throttle.
I’ve always used as large a split-pin as will fit in the hole, then put the end of the spring through that.
If you do it that way, make sure the other end of the split-pin has no sharp edges that may catch on anything.
I hope that helps....
by tommy200184 » Thu Aug 04, 2016 8:31 pm
Ok, I will try. Thank you.
tommy200184
by Digger » Fri Aug 05, 2016 7:24 am
As Mark said you use a split-pin through the hole in the bar and then stick the spring through the loop of the pin.
Digger
by tommy200184 » Sat Aug 06, 2016 7:04 am
Hi, it's done, and it's ok. Thank you.
tommy200184
